Hello Group,
Good News and bad news. The bike is now running...yeaaaaaah! Bad news, I don't think one of the cylinders is firing at all. I had my uncle come over here today with a temperature reading gun and compression tester. Here is what happened.
1) Cold Compression in the right cylinder was 75 lbs and on the left cylinder compression was 120 lbs.
2) After squirting some oil in the right cylinder compression went up to 110 lbs
3) We also started the bike, ran it, warmed it up and checked compression. On the right side it was back at 75 lbs and 120 on the left side.
4) Spark plug on the right cylinder is black and spark plug on the left cylinder is white and clean.
Here is a picture of the old spark plugs, I pulled them out and replaced them with Iridium plugs. However, the new Iridium Plugs look exactly the same.
We checked the temperature of the head pipe coming out of the right and left side. The temperature on the right side was 30 degrees colder than the left side. Then we shut the bike off and pulled the the plugs.
The new plugs looked exactly the same as the plugs in the picture. The right spark plug is virtually wet with gas.
Then we put the the wire boots coming from the coils over the plugs while they were out of the bike to test the spark on each plug. The size and intensity of the spark was identical so we know the cylinder is getting spark but the fuel is not combusting.
We put the plugs back in the bike, started it up and then took the air/fuel mixture screw all the way down. The bike still ran the same.
What do you think is going on here with the right cylinder?
