rude
I just changed out both front calipers on my 78 for new Mikesxs units, this meant a night of bleeding the brakes, prior to this I was appreciative of having littlebills "how to" post to study as I always seem to spend a lot of time pumping the lever before getting pressure up, littlebills suggested method of
1) pulling the brake lever in. 2) opening the bleeding nipple and pumping the lever. 3) retightening the nipple (just snug). 4) Releasing the lever.
Helped to get the fluid into the calipers
but
I was always taught this method
1) pump the lever (peddle in a tin top) slowly and avoid bottoming the lever out (short slow strokes) 2) hold the lever in/ release and close the bleed nipple, lever bottoms, observe fluid and air exiting in the bleeder tube. the action of the lever forces the fluid and air out
Repeat until air is gone and you have good (not spongy) lever action
"If" I pumped the lever fluid just moves back and forth in the tube.....
comments? did I miss the plot?
I'm bleeding again tonight just to be sure (to be sure)
Why two new calipers? bought the thinner drilled discs and could not stop the fluid leaking past the pistons, even though they and the seals seemed in good order (new seals), I can only assume caused by the change of position of the piston due to the narrower discs. Got sick of pulling them apart so went for the "change it all out" option as I wasn't going to compromise with brakes
but
