xs650dude63
Hey everyone, im trying to bleed my rear brakes, I bought a new master cylinder from Mikesxs, I used the syringe method to makes sure very little air was left in the system, ok so I got the master cylinder back on, went by the directions in the work shop manual and its not working, I keep pumping the brake pedal and nothing is coming out,I got the bleeder valve open all the way open, resivour is full with fluid, when I pump the pedal a tiny bit of fluid comes out and thats it. I did adjust the push rod so it would go into the MC farther and that didn't help, I got the other end of the rubber tube going into a container submerged in fluid, but the brake pedal goes full travel up and down and nothing is coming out. Is it possible the Master cylinder I bought from MikeXS is bad???
