Sold / Found / Inactive - Boyer-Bransden Ign
halfmile
XS Builder
XS650.com Supporter
kansas
I bought this new for my No Theme Build and used a HHB CDI instead. $185 shipped in US.
Does this require that you change alternator as well or does it work with the standard set up ? I’m mostly into using the original points type - but my last rebuild cause me a lot of trouble getting it set correctly - done 4 previously and they all turned out fine, but this one seem to keep getting out of wack whatever I do ( looks all good when I check it static, but as soon as I do the dynamic check it seem off on one or the other cylinder ) so I’m thinking about ditching the point although I don’t like the expense of the electronic options !
Nope... doesn't have anything to do with charging. You keep the original alternator.
