Boyer Bransden Ignition Mounting Bracket
mouth
XS650 New Member
Gibsons Canada
I've recently designed a mounting system for the Boyer Bransden ignition system. It incorperates a solid mount for the coil and ignition module, so you dont have to zip-tie anything. It is a simple "drop in the parts and bolt it in place, put your tank back on and ride the damn thing". Here are the specs:
Billet aluminum
Mounts in to the original coil location
Two configurations - one Stacking (module over top the coil), the other is Hidden (module between the frame gussets).
Could I get some feedback from all of you as to weather or not this is a good idea and you guys would buy this thing?
What price would you pay for something like this?
Would you like material options like Brass or Stainless Steel?
Here is a rendering of the stacking config... (its used for bikes with peanut or mustang tanks).
The rendering isnt 100% accurate, but the idea is there.
Please let me know your thoughts.
How are you protecting the blue box from vibration?
I used a short section of aluminum angle material from Crappy Tire. Bolted it to the frame coil brackets. One side for the Boyer coil, one for the box.
Held up for a few seasons and then I switched to a Pamco for my 277 rephase.
I'd have shelled out maybe $40 for a ready-made solution but there aren't a lot of Boyer's out there given the expense.
Its a good idea. For my Boyer I used a rubber mounted alluminium plate and used velcro to attatch the unit to the plate - it adds another layer of vibe damping and is easy to remove
Billet aluminum
I just installed a BB system in my '82 - late Specials have a different coil mounting bracket than earlier 650s, so that would further limit the market for the one you have in mind. All I needed was a short length of 1x1 aluminum angle and a couple of short standoffs.
Billet aluminum
I'm working on my bracket now. In your rendering I don't see the ignition coil in place. Another thing I wondered about when placing my processor was that if it's right next to the coil could it be affected?
Don't know if you all are looking for chopper solutions, but I put the box in my fake oil tank. I used bicycle tube to isolate it from vibes:
The coil mount is simply a piece of 1/4" plate welded to the neck gusset cross bar:
I see you have some good solutions. I am putting mine in a stock 1974 650. I have my coil nicely mounted using spacers and one of the old coil mounting holes and one I drilled. I'm mounting the processing unit up closer to the neck to keep it away from heat. I fabricated a bracket using some brackets from Home Depot. I'm using a neoprene foam for antivibration. I'll probably post some pictures when it's done
