Ok... i just f*in' wrote a whole elaborate tale and it got deleted because I exceeded the time to post.
Im going to try to make sense and not waste so much time.
Im trying to see if the boyer bransden unit that the previous owner installed is installed correctly. Last night I decided to tinker with the poop-mobile once more since I got the new brass from sudco. I was playing with the timing and wanted to check something i've encountered. When spinning the hall effect rotor,
Ive noticed that it sometimes rotates the entire assembly and sometimes it doesnt and just spins through. I've tried rotating the assmebly by spinning the alt stator and by spinning the nut on the advance side of the boyer unit to see if there was a difference. What i noticed was that when I spun the stator the hall eff. on the ign unit spun without any hesitation and always lined up on the intented mark, but when I was playing with the nut that secures the ign hall eff to the cam:
, the results were inconsistent and sometimes the stator would move and sometimes i was able to just spin the hall eff. independently. What I want to know is if its normal to see what I am seeing, or maybe the hall eff. shaft needs to be mounted tighter so when rotated it rotates the entire assembly without any slip. How could I go about tightening it without damaging anything considering it spins through so i need to grip on something to tighten it.
