Wanted - BOYER SETUP
timbeck
HARDLY A GURU
XS650.com Supporter
XS650.com Supporter
Boston,MA
Hunting around for a used Boyer ignition setup.....
I have had my engine re-phased so it is back to coils for me, are these any good they were working good
Morning---Thanks for the reply. Yes those are parts that I need for my ignition. An important part is the plate with transisors that mounts on the left side of the engine under the cam cover. Let me know how much you want to sell them for. Thanks tim
Hey Timbeck,
I'm sort of a nervous type when it comes to magic electronics and their sensitivity to outside interference but when you install that system I would strongly suggest that you don't tie wrap the brains of that Boyer to the extremely high tension coil pack! If it were me I would try to give them at least a few inches apart just to be safe. Just my unsolicited two cents!
Thanks Packrat, I have done a few of these systems before and I place the blue box under the fuel tank. The coil gets fixed under the horn and all seems well. Until you crank up the bike uithout the plug wires hooked up......
