wingman1946
1978 XS 650e
I have flushed out the MC and got the fluid to finally flow down to the bleeder nicely but can not seem to build up any pressure. I have probably run a whole can of fluid thru it without bubbles. Any ideas welcome.
I did have the complete MC apart. Maybe I will give it another go. Cleaned the square groove in the caliper plenty good. You are right lots of bad stuff in there. Can you advise me as to what is suppose to hold the rubber piece onto the small end of the spring. do I just put it down in there and hope the plunger will hold it in place? Just wedged in between the plunger and spring?Just flushing usually doesn't clean all the goop out of a MC. You really need to take it apart. If it's not leaking any fluid, chances are good that the rubber bits inside are still OK. When servicing a caliper, one of the most important areas to get clean is the groove for the square sided o-ring seal. It gets a crusty build-up of dried out brake fluid down inside it and that forces the o-ring out more, causing the brake to drag and piston to stick. I'd try this thorough cleaning before I started replacing things.
rubber piece onto the small end of the spring. Just wedged in between the plunger and spring?
If you had good pressure before the fluid change, then you probably still have air bubbles in the system. As was suggested in the link offerred by NONclow, just walk away from the bike for a day, and let the bubbles migrate upwards into the M/C. Gently adding some high frequency vibration ( just snatch your wife's vibrator when she's not looking ) to the components could help the bubbles move.
