Sparky
hey all.
an update on my build. it started here- http://www.xs650.com/forum/showthread.php?t=30278
but i didn't want to drag up and old thread.
So here's progress. Ive got my seat mounted, 12" ape hangars (TC bros) mounted, wiring all done, tailights wired in, rear fender mounted, carbs cleaned and adjusted (mostly), new tires on the way, new brake pads, and most recently, about 15 miles put on it putting around the neighborhood. (the most i've ever ridden the bike)
I had hell with the carbs, i just couldn't get the left cylinder to fire. tested everything, but it all came down to the washer and o-ring under the idle mix screw- the washer wasnt there. just a tiny little .99 cent bit of nothing, but it will sure make ya want to scream. the carbs are still stock jets, so my next order of stuff will be jets and yet more o rings and gaskets.
still a million things to do, but being able to ride it around feels like a giant progress step.
left to do- the seat springs are way too tall, shorter ones are on order. the front brake hose is too short. forward controls are in the works, and and needed. those mid controls just dont work with that seat and bar position. I'm having trouble with sticky shifting, and it randomly pops out of third (or finds a neutral between second and third), but all that will be fixed in time.
Posted via Mobile
Posted via Mobile
