wherearewe
Rub on Ya Titties
So i finally came to re-assemble my rear hub. All new brake components, powder coat, chain and sprockets etc.
However when i was chasing the threads on the hub before fitting the new sprocket, i discovered one of the bolts has sheared off about half way down. I guess there is about 10mm of bolt left in the hub. I didnt even notice when i was removing them. Looking at the original bolt (which i kept) it looks like it has been like that for some time. They look a little corroded but not shocking bad.
My question is what should i do? Penetrating oil and an easy out? Im vaguely scared of breaking an easy out inside the hub, and it looks pretty well settled down there. Cut down one of my new bolts so 1 bolt is shorter or refit the old one? Def seems a bit sketchy but i dont think it would do too much harm. Still has 15mm of thread or so plus lock tabs. Take it too a machine shop and let a pro deal to it?
Opinions or tips?
Thanks in advance
Opinions or tips?
Thanks in advance
