MFJustin
Welcome to Thunderdome
Picked up an '81 motor to use in my current build. It came with the BS34's, pulled all of the jets and it seemed like the PO had gone up quite a few sizes in everything. Carbs needed a pretty thorough cleaning but I've got everything mostly finished up save for redoing the jet sizes.
My plan was to take everything back to stock, 132.5 main jet size and a 42.5 pilot. The set up is going to be a PMA/Pamco, UNI Foam Filters and the stock exhaust cut down before the muffler so essentially straight pipes. I know that I will probably have to tune it more when its all said and done but I wanted to take everything back to stock sizes and work from there. As it stands right now I have all of the stock jet sizes ready to go in, the one tip I took into consideration after reading around here was to swap out the fixed clip needle with an adjustable one. I picked up this needle from Mikes XS which I'm hoping was the correct one. http://www.mikesxs.net/product/48-0663.html
My questions in regard to this easy swap are:
1.) If I am taking all of the jets back to stock sizes for a baseline to start the tune on, what position on the needle should I place the clip that would be "stock". I'm assuming that once I get everything buttoned up and start to fine tune it, I can just follow the guidelines for BS38 needle adjustment?
2.) Does the rubber donut with alignment hole from the stock needle need to be swapped over to the new adjustable needle? I am going to assume that it does need to swap over but I wanted to check first.
Included are pics for reference. Thanks in advance guys!!!
