What's the best/easiest way to remove the mixture screw plugs on the BS34's without destroying anything? I've got one carb (left) that seems to be running a little lean, and I have checked/replaced everything else except the mixture screw settings. Everything else is in sync. I just want to check the screw settings and adjust if necessary.
Thanks,
bpd106
Thanks,
bpd106
