glennpm
Another Old Biker Nut!
Hi,
I've recently finished my 1979 XS650F and am having bad low speed stumbling, i.e da ..da..da, off-on-off-on stumbling and missing off of idle to about 2300 -2500 RPM. The first couple of short rides I made a few weeks ago were fine without this problem. The bike sat for about three weeks with about a half tank of gas and then on Monday morning I took a short trip and it was bad right out of the driveway.
I have a completely rebuilt 277 re-phased motor. The carbs were completely overhauled and I have new diaphragms. I'm running Uni pods. I have the small glass bowl with bronze filters on both card gas inlets. I have Norton Commando mufflers and no cross-over pipe. I port matched and polished the heads. I deleted the lower barrel to crankcase gasket, raising the compression ratio a bit, maybe .4 or so. I have a vacuum hose connecting barbs from both carbs. The carbs are set up this way (post quoted from 5Twins):
"Re: Bs38 Carb Re Jet Question.??
" ... For the '78-'79 carb set, start with one up on the pilots (27.5 to 30), one to three up on the mains (137.5, 140, or 142.5), needle clips raised one step to slot #2 (lowering the needle), and mix screws about 2.5 turns out. It's very easy to over-jet these CV carbs because of their forgiving nature. They work on engine demand and the slide only lifts as much as the engine can use. That's why the bike may seem to run OK with a main jet several sizes too large. The slide isn't lifting all the way and that large main isn't flowing at it's full potential.
To properly test the main jet size in these CV carbs, you need to use absolute wide open, full throttle (just twist the grip open as much as it will go). In 2nd or 3rd gear and starting at about 3K, run the bike up to near redline. Watch for glitches (stumbles, flat spots, break-up) and note what RPM they occur at. This will tell you what needs tweaking (needle, main, or maybe both). Full details on this test and also one for the idle/lower mid-range are in the carb guide. In fact, pretty much everything I just told you is in there, lol."
I started with the pilots out 2 1/4 turns, adjusted both sides listening to RPMs and feeling exhaust pulses. I ended up at 2 3/4 out on both carbs. I have not balanced the carbs yet. It did seem that there was more vacuum on the right side then the left, based on feeling the vacuum hos. It was actually visibly partially closing the hose on the right. The valves are adjusted properly, TDC accurately established and timing correct. Both carbs needles seemed insensitive to change on the richer side, i.e. more open. Color for both spark plus is identical and good light tan color.
After adjusting the needles there was improvement but still not real good. High speed response is awesome. I'm surprised at how strong and fast the bike pulls up to 5k from 2500 with NO flat spots or hesitation.
I dosed my gas with 5oz of Seafoam last night and topped it off in the garage but won't be able to test again until Saturday.
Since it ran good, albeit short trial rides and now isn't, I'm suspecting a bad gas problem. Any suggestions?
