Im cleaning up a set of bs38s and I am going to go all in and put new butterfly shaft seals in. I have the butterfly screws out however, the butterflies themselves are not sliding nicely out of the slot in the shaft. Is there a trick to it? How much force should I be using? Pull out with pliers and a rag? Bang out carefully with a plastic drift or something? They are loose in the shaft but are binding up on the carb body. Thanks.
