This thread looked like a good one to catch a ride on...
I pulled my BS38 (CV) Carbs off and disassembled them this past weekend.
Here's what I found (as installed by PO's) as far as installed Jets, etc.
Main Jets: 135 (small round type)
Pilot Jets: 27.5
Pilot Jet Style (based on Float Bowl type): VM22/210 Series
Main Nozzle (Needle Jet): Z-8
Jet Needle: 4M1
Needle Position: 3rd groove (middle)
Comment on Needle Jet Condition: No sign of O-rings on either Needle Jet. What symptoms would this cause?
What can be concluded from above Jetting?
When I bought the '76/C, I noticed that the air filters appeared to be a foam type and the foam had all but disintegrated, so there was essentially no filtration.
To remedy this, I installed a pair of K&N YA-1152's which fit nicely into the factory airboxes. I also installed new foam rubber strips in airbox covers to provide a little better seal.
Would the use of the YA-1152's necessitate re-jetting? I've got everthing apart, so now is the time. Not sure what to make of the jetting I found.
I'm going to replace all the jets and probably the floats since they are pretty crapped up and specifically the main jets are all mangled from screwdriver abuse (some by the current owner)...
Oh, I've attached some images that were taken on the right carb. Taken toward the bottom of carb just above bowl. I noticed that a throttle part (?) moved toward a post that has a threaded hole, but I've got no bolts/screws in the hole.
Am I missing a part?
