hrtnalbertan
Hi guys,
I've been creeping on these forums for a while and find the site to be an excellent resource. That being said, I could use a bit of help! I recently picked up a near mint 78 SE with fairly low mileage. The bike is fitted with cheapo k&n tapered pods and running really lean. I've capped the intake ports, adjusted the cam chain tension, valves, and checked the points. I've made sure that the floats are set up properly, cleaned the carbs and been fooling with jets and needle adjustment with no luck. I noticed that one slide was dropping faster that the other under vacuum so I ordered replacement diaphragms. I just replaced the suspect diaphragm and it still drops quickly under vacuum. Is it possible that I have a vacuum leak coming from the enrichner on this carb? I'm running out of ideas and would appreciate some new points of view!
Thanks
Thanks
