The CV carbs used on our bikes (both the BS38 and the BS34) have a true mixture regulating screw, NOT AN AIR SCREW as it is often erroneously called (even in the actual factory manuals). It regulates a portion (approximately 25%) of the fuel/air mix coming from the pilot jet. So yes, opening the screw makes the idle circuit richer, closing the screw leans it out. An air screw controls air flow to the pilot circuit so opening it adds more air and leans the mix.
A way to determine which type the screw is on probably 99% of the carbs out there is by its location. If it's between the slide and the motor, it's a true mixture or fuel regulating screw. If it's between the slide and the air filter, it's an air screw.
