rude
Dunno about you blokes but I really like pictures, I get ideas from looking at your work and I hope it is reciprocal, attached is my resto/cafe to date.
I've been working through the first fit prior to pulling down and painting, polishing, fixing POs bodgey wiring and some chrome for the extra bling.
last night I got the seat base on and fitted with rubber mounts, sits well I think! I'll be fitting the cafe/brat tail light tonight that I scored from DCC ,as well as making up a number plate bracket
I'd like to paint the seat base so I'll be fibreglassing the sheet metal section I added.
The front end is all done with the ACEWELL gauge and the wiring re adjustments to suit including a headlight on off switch, that was fun!
Front fender is a Mikesxs cafe fender, as he states it is a tight fit, I had to use builders clamps to push it in so as not to damage it while getting it into position, drag bars with an inch cut off either side, fabricated ignition switch mount and chromed switch gear, I'm just waiting on a new chromed master cylinder from usamotorcycles to finish. I've also replaced the steering head bearings with tapered bearings, rebuilt calipers, new pads and braided S/S brake lines
Now the big question(some say the fun part) what colour? I'm after that trad Brit cafe look and am inclined to go for silver with black stripes through the front fender, tank and tail section, I'm open to ideas.........
Some pics below, apologies for the poor quality and background
On a side note do you guys from the USofA realise how lucky you are with easy access to good products over there, the $ exchange rate must get some credit for this rebuild.
cheers
cheers
