avenue
push.
How tight should new bearings be on the ends of a cam shaft? The four external bearings, not the bushings.
Four new bearings showed up recently from Mike's and they seem a bit tight on the ends of the cam. Two will slide onto one side with just a bit of persuasion, the other two will not slide on by hand without feeling like they're binding. FYI, The old ones slide on with little effort.
what's SOP for installing new bearings? by hand only, rubber mallet to get started, pressed on? and, is it a bad idea to use a combination of three old bearings and one new bearing? (only one of the old bearings feels crunchy but I ordered all four new ones, anyway).
