missile150
Ok, here is my next setback. I wound up getting a new cam chain for my 1980 engine. I tied it to the old one to fish it through, but of course it came apart halfway through the fishing. So I fished it through and "believe" it is sitting on the gear in the case correctly. Then I installed the cylinders, lower head and then peened the new chain together with the master link thinking I could put the cam under the new chain like I took it out before I decided to replace the chain and split it. I also replaced both the front and rear tensioners.
My problem is now the chain seems too short and I can not get the cam under the chain. Now what? Do I split the chain again, or is it possible it is not sitting in the case correctly? When I move the pistons up and down, the chain moves freely and I do not hear any metal rubbing or anything. I can get it under a set of lobes, but then get hung up on the head bolts being in the way.
Please help. This is driving me crazy. I knew the new chain would be tight, but that tight, really? Thanks.
