Engine is out and I am in the process of buttoning the engine back up after a top end rebuild and cam guide replacement. This is my first XS rebuild so I am learning as I go. As I was replacing the cam chain, I had a major hiccup. Long story short the chain fell down in the motor before I hooked up the master link. I managed to fish the chain out, but the master link fell out in the bottom end. The case still has oil in it and is bolted to an engine stand. I am trying to remove the drain bolt but cannot get it to break loose on the bench. My next step I suppose is to remove the sump plate bolts. This will make for a nice mess but what are my options at this point? Also, can I feed my cam chain from the top and rivit it through the sump plate while it's off? Is there a simpler way to feed the cam chain through the crank?
