Thanks to Littlebill31 and all of the other experts. I fired by xs650sj Heritage special today and I had this terrible noise. I have inadvertently changed the cam tension adjustment while trying to track down an oil leak. Oh and by the way, I think I have slid off every slipper slope of xs650 misadventure so far.
I have had my kick start mechanism prevent me from close my right have case. Excellent video from a UK gentlemen on this subject. I have over torqued my valve adjustment screw and have popped out the clutch cable. I have replaced my clutch shaft seal and bushing and have put in a Mikes one piece clutch rod only to be greeted with a few more drops of oil this afternoon.
I have also retensioned the number 3 and 4 starter gear drive springs to have continue to spin off the drive mechanism. I tried to get to a 0.625 spring length.
Oh well, keep the videos coming, the written material on the carburetor rebuilds are just fine, only they make a lot more sense after you have actually done the job.
For tomorrow, I will fix the gas tank leaking issue with some non fiber washers for the petcock fastener, probably neoprene or something like that and I will have the good folks at my local Yamaha shop cut me a new gasket for the petcock as well. The O-ring is new but the surface has been repainted a few times and could use some smoothing out with sand paper or a wire drill.
Kind regards, am enjoying all of the information and the technology behind these bikes.
