Fernando
I have been at this for some time now, motor back and forth in the frame FOUR times! I am at my wits end.
Replaced front cam chain guide successfully.
When I time the cam shaft (machined slot in 12 oclock position) with the crank (mark on alternator rotor in line with T mark on stator cover) and cam chain tensioner in, I spin the motor counter clockwise via the 17mm bolt on the crank, and everything lines up. I put on the valve head and spin the motor some more some how IT GETS OUT OF TIME, the small hole for the advancer unit (which is in the same position as the machined slot) is no longer in the 12 oclock position but around 10 oclock.
http://www.650motorcycles.com/CamTiming.html
Moments before it was at 12, with the cam chain tensioner installed. Is it possible that the gear on the crankshaft has slipped, but only some???? What am I missing here?
