Can anyone confirm that the Clymers and Haynes manuals are a bit misleading where they describe how to install the cam. I believe the Clymers asks for the left side piston to be at TDC on compression stroke (which is already misleading because without a cam all of the valves are closed), however, the timing mark on the left side of the cam should be vertical, which means the left side valves are NOT closed, so how could the left side piston be at TDC on compression...But the right side would be be...
The Haynes manual does not depict LEFT or RIGHT side, it just says position the pistons at TDC on compression stroke. Again, if you're installing the cam, how can you determine compression stroke or not, there is no cam yet to open any of the valves.
I'm referring to completely stock stuff here.
My motor is rephased, but the left side remains essentially stock. I've put this motor together several times. I know how the cam / crank need to be timed to each other.
I was just brushing up on how the manual describes the install process, and it seems to be misleading? Am I missing something?
Thanks in advance
Thanks in advance
