Hi again Grewth
Thanks for those pictures.
More questions
Hopefully this will be the last.
Refering to the picture below, the red line intersects the centres of the mounting holes, does that look to be in the right place to you, or could it go left or right a bit?
The holes are set at 3.4mm at the moment but that can be adjusted.
Refering to the second picture, can you get me a couple of good pictures directly edge on where I have arrowed so I can see the shape of the cut out profile?
If the profile is rounded could you find something that fits nicely, maybe a Sharpie pen or the shank of a drill bit?
Also could you take some measurements at the three places where I've marked with double arrows?
And finally the mounting lugs, I've set them 7mm down from the top in my cad picture, is that correct, or do they need to be 7mm up from the workplane?
Neil
