Okay, "Tater" (It's a Yam, ya know...) is in the tuning stage.
The carbs were disassembled, cleaned and reassembled using the Carb Bible from this site.
I have an intermittent problem on the left cylinder. The first time I went through the carb adjustment procedure, the left cylinder wouldn't run unless the idle mixture screw was WAY out...like 5 turns out.
I took the carbs back off, checked the float levels (they were within spec @ 25mm, but I tweaked them to 24mm while I was there) and put them back on.
Same problem. It seemed to run better with the choke on, so I quickly covered the carb throat with the palm of my hand (air boxes off at the moment to facilitate carb removal/replacement) and once it cleared the surge of gas, it ran perfectly and I was able to adjust the mixture via the dead cylinder method. Shut it down and came in the house for a bit.
Went back out to start the bike and check the charging rate, and the problem was back. Left cylinder won't run unless the idle mixture screw is backed way out.
Ratzenfratzenfrickenfracken...
So, looking at the diagrams, reading the bible and scratching my head, I figure I must have missed something in the left carb's pilot circuit. Plan at this point is to take the carbs off and tear the left one down again and double check all the passages with particular attention to the pilot circuit.
Anything else I should look for while I'm in there?
