seth1981
Ok Im needing help. Im not a carb guy but I want to figure this out so I dont have to take it to somebody everytime it need adjusting.
My first issue is pilot jets. I was going to buy a few different sizes and noticed on
http://www.xs650direct.com/products-39.html
The little diagram they have shows two different type of jets. VM22 and bs30. I have a 74tx650 with (from what I can see 74 carbs) but the jets in it look like the vm22 jets they have listed. Now im going directly off the picture. Mine, like the vm22 have the multiple holes on the side. The ones it has for my carbs only have 1 hole. Can those two be swapped out and work I.E. diameter, threads ect? If so and the wrong one was in my bike what issues would that cause?
Ok #2. I just picked up this bike. It had a low end stutter but when I grabbed a handfull of throttle if ran fine. Came with 127.5 main, needle in 2nd (from top) slot I Switched up jets. Cant remember pilot size, 130 main and needle in the middle slot. Went out and ran it and the low end stumble was much better but it sputteret really bad at the top end. When I pulled the carbs after the bigger jets there seemed to be alot of gas in the carb.
Ive tried just about all variations of the jets I have and needle positions and it just switches up from top end sputter to low end sputter. Carbs dont have a leak (just rebuilt) valves, timing chain ect all good to go. Im lost here.
What I do know is it starts fine no matter what I do. So I have that going for me. Mix screw 3/4-1 turn out. I have read and re-read the carb guide on here but its not helping.
I cant for the life of me get the idle to stay. When I start if even after its warm its fine. After I run it its really high.
Ive tried googling flat spot and stumble so I have a better idea of which is which but got nothing. I say sputter because its like the engine is not getting enough fuel and sputtering kind of sounds like a machine gun.
Last thing is wiring isnt the greatest but I keep the batt on a tender so its fully charged but could a bad ground or grounded wire be hurting? I know its not good but I would think if thats going to mess it up it wouldnt be top end one jet size and llow on another size.
Anybody have any suggestions? Altitude about 2300 temp 50-60 deg F.
So there it is. Sorry for the length of this post. Thank you for any help you might have.
