kenco
Hi, i want to up a size on the main jet, I take it the next size up from standard (122.5) will be 125. I have read the carb guide, but i haven't seen a copy of a size chart for main jets. Also i want to drop the needle by 1 notch, If the clip is on notch 3. Does it mean drop the circlip to 2 or 4 ??
Also replaced the pesky starter spring, had a couple of goes at rebuilding the clutch housing, on the second attempt i found that the center hub was running out alighn. I removed the basket and that the needle roller bearing had broken up and the thrust washer that goes on before the bearing broken. Am i right in thinking its an error on my part not making sure they were seated properly before torquing up the nut. Or is there an underlying fault elsewhere.
