It is truly best to get it running the way you have it. After you get it running correctly, then you can start to modify. I say this because of what I have seen from others. Some start ripping things apart without even understanding how they work, then chase their tale for weeks on end trying to figure out it was just some debris.
Clean them up, and I mean clean clean. Check every little piece, port, crevasse, everything. Use compressed air to blow out all the little ports.
You will also want to start spraying carb cleaner through ports to see where they come out. This helps explain what they do and how the fuel travels throughout the carbs. Most just spray all over the place and call it good.
The smallest amount of debris can cause havoc.
Have fun with it. Carburetor knowledge is a great thing to have.
And the K&N air cleaners aren't the best. I like the ones from MikesXS.
