I haven't started my bike yet so I'm unsure how much of a problem this will present. My left side BS38 carburetor has some wear internally where the butterfly valve , under pressure from springs on the butterfly shaft , have caused the butterfly to wear into the carb body. To remedy this , the PO fabricated a really nifty shim made from a beer can then he wired it in place and covered the whole mess with a big blob of unknown substance.
These pics were taken prior to dis assembly and cleaning. I'm sorry I never took any good pics of the wear inside the carb body.
I replaced the novel beer can shim and black goo with a shim I made from filing down a washer until it was very thin. This did a good job of pulling the butterfly back to center and everything works smooth. I just don't know if it will leak air and if that will be problematic. Here is another pic inside and if you look along the edge of the body you can just barely see the damage.
Sorry I didn't take any pics after the repair.
So do you think this will come back to bite me? I'd hate to think my carb body is ruined.
