msellarole
Here's the issue:
After emptying the carb bowls on the 1982 xs650 just as a routine check, I put the bike the left side stand. Ten or so minutes later I noticed the left air filter was leaking gasoline (maybe a drop every three seconds). After taking the filter off, I still couldn't identify from where inside the carb the gas was leaking from. When on the center stand, the bike still only leaks from the left carburetor.
A few more obvious checks I did:
The leaking obviously stopped after turning the fuel petcock off. The leaking was much slower to start after I had drained out the left carb bowl.
I am a complete newb to motorcycles and engine mechanics in general. Any ideas as to what might be going on here?
Any words of wisdom would be appreciated.
