I got my '75 (basketcase) a while back and the carbs were so gunked up, after taking off the tops and pulling up the edges of the diaphrams, I worked the slides free by levering them with the wooden end of a cleanimg brush. Probably not a recommended method, but I got them out! Then disassembled the carbs (one at a time, so I could see how they went back together, with the Haynes manual right next to me), and scrubbed them (mostly) clean. Then, all the metal parts went into "The Dip" I got from N.A.P.A. for an overnight soak. After a good rinse, dry, and sprayed with carb cleaner (which contains a lubricant), re-assembled. They function okay, but on the next tear-down, I'm going to soda blast them down to the bone and re-gasket everything, so they should be good for another thirty years! Hope I can take better care of it than the previous owner!
Posted via Mobile
