Crackers61
Crackers61
Hi Guys,
Does anyone have the measurements for the brackets that holds the two carbies together? The upper one. The lower bracket is a small angle piece, which is screwed into the body of the carbs.
I'll need to make these.
The reason i ask is I'm about to assembly two carbs to a new engine which i have built. I also have to make the linkages up that will control both throttles and also make the linkage for both chokes.
Wondering if anyone has done similar?
Regards
Crackers.
Regards
Crackers.
