650hcs
Addict
-All makes and models
-Bead Blasting
-Ultrasonic Cleaning
-Quality Carb Kits
-New Lines/O-rings
-New Gaskets
-New Jets
Carburetors are first completely disassembled and all parts are checked for wear or damage. All parts are then bead blasted to get all dirt, oil, and road grime off and to achieve a nice satin finish , Then all parts are placed in an ultrasonic cleaner with an industrial strength solution to make sure all passages and jets are clean and clear. After that they are dried with an air hose to blow off any particles left behind. Carburetors are then rebuilt using quality carb kits, all parts are replaced or cleaned. My goal is to exceed your expectations in the quality of workmanship put into your carb.
Price is $75/carb plus parts(carb kit)
Parts are usually $15-$30 depending on carb.
You can reach me at centexcarbs@gmail.com
or call me at 512-508-6608 call anytime
or you can pm here
My name is Holden
Here are some pics of a extra Mikuni BS-38 off my 75' xs650 I cleaned just to show the quality of my work.
-Bead Blasting
-Quality Carb Kits
-New Lines/O-rings
-New Gaskets
-New Jets
or you can pm here
My name is Holden
