So, dumped the oil and pulled both filters to change out, while preparing for clutch change. Stuck around the lower filter, and under it, were long black plastic pieces which I assume is the chain guide. Attached is picture.
Couple questions, I hear it is concern when you see aluminum shavings, however how normal is it to get these pieces floating around? Will you get some between oil changes? As I am doing a tracker build, my intent was to finish assembly and work electrical/mech bugs out this summer. Next winter pull engine again and replace guides. I am trying to judge risk and normality of pieces.
