Yes, I know the clutch have been covered, but I couldn't find any solution in all threads I read. All seem to cover slipping, neutral problem, gear problem etc. I don't have those problems. My new clutch cable make the clutch work okej regarding engage, disengage, finding neutral and gears.
My problem is that with the new cable I don't seem to be able to adjust the lever to start disengaging the clutch when the lever is closer to the bar. Now it's engage and disengage when the lever is almost out. The lever adjuster is screwed all the way in.
The old one made the clutch engage/disengage well and I could adjust the lever so it didn't disengaged to fast and to late at the bar. More towards the bar though. The only problem was that the wire didn't go easy and smooth anymore, even with lubrication.
Anyway, I installed the new one, adjusting accordingly. The clutch engage and disengage good, it doesn't slip and I can find neutral easily. But now it seems that even with the lever adjustment screw all the way in, the clutch starts to engage with lever almost all the way out, which is not comfortable. And there is no way to adjust the lever so it engage/disenagage when the lever is more towards the bar. Even though it doesn't slip now, this normally happens when the plates are worn and and you start screw out the lever adjuster screw. But since I could adjust the lever to engage/disengage closer to the bar I dont think my plates are worn.
When adjusting the worm gear, I had the cable housing in the upper lever adjusting screw and the screw all the way in, most slack. If I have it completely loose/off and then adjust the worm gear slightly differently, I can't get the cable housing onto the lever adjusting screw. To enable that I first have to back off the worm gear screw, screw the lever adjuster all the way in, put the cable housing onto the lever adjusting part and then readjust the worm gear.
I can't seem to be able to get the lever to engage/disengage the clutch while closer to the bar, which I could with the old cable and which is more comfortable.
Is the cable housing to long or am I missing something here?
I just want to point out that with the old cable I could adjust the lever to start disengaging the clutch when the lever was closer to the bar. Why not now?
