leggers
- Messages
- 138
- Reaction score
- 5
- Points
- 16
OK, so I was reassembling my case and I notice this crack on the inside arm of the top case. If you're familiar with this area you know this sits right above the crankshaft bearing, and is reinforced with a steel bracket.
SO my question is. since this area is reinforced with steel should I be ok to use this top case? or do I need to consider getting a whooooole new flippin case?
Lucas
In this photo you can even see the locating pin is pushed waaay down which is probably what caused the crack...
Lucas
