I'm looking for a 32 or 34t rear sprocket for my XS500 rear wheel, 530 chain, must be steel. 4x110 mm mount bolt pattern, 74mm bore. Anybody have any leads? Or will it have to be a custom piece?
I don't know what the difference in bolt pattern is, this sight list a '75 xs 500 and a '76 up xs 500, 29T up and 34T up respectively. Hope this helps. Was thinking about doing an 18" rear mag myself. http://www.pbisprockets.com/Catalog.html
hmusket, that's the early 6 bolt. I have a later 4 bolt hub, I should have mentioned that in the beginning. That PBI catalog page shows the early 6 bolt sprocket as well but they show an RD400 sprocket available in the size I want with a 66mm center bore, where JT only shows the 38 and 40 tooth version. I suppose it's possible to have a sprocket center hole machined from a 66 to a 74mm diameter. PBI does get me closer!
My mistake, didn't look at the picture closely enough, you did mention the 4 holes. Here's another one, I was thinking of using it for my bike. I'm putting on an XJ550 wheel. http://www.jtsprockets.com/52.0.html?&L=0&sel_uid=4785&p=
Just need to drill the mount holes a little bigger.
