YL82
Perpetual Restorationist
Somehow I've sustained a divot/dent to my aluminum head on the gasket sealing surface. Not sure what happened or when.
I talked to a welder friend of mine about TIG welding to fill in the cavity, but he felt that the heat would likely create some warping plus the issue of grinding it down. Not a good option. He suggested using some sort of filler when installing the gasket.
Any ideas or thoughts on what I need to do if anything or wil the gasket take care of this on its own?
Thanks.
Thanks.
