Blue, could you explain a bit more about that LCU (Light Checker Unit)? I'm thinking it may be something I'd like to eliminate. What exactly does it do and I'm assuming I can't just remove it or the tail light won't work? Does it only affect the tail light?
First let me explain something.....I am not advocating riding a motorcycle without having your headlight on. I simply prefer to be able to reduce the power drain of lighting if un-needed and for all kinds of reasons..... be able to turn my headlight ON or OFF independant of whether by bike's are running or not. Usually in daytime backroads, off-roads, dirt roads or trails with camp and fishing gear strapped on etc. In my opinion these systems (RLU, TSCU & LCU) were largely unnecessary "bells & whistles" and have now become either defunct or in some cases new hazards of unreliability themselves.
So saying... The LCU is an rubber encapsulated unit almost identical in appearance to the TSCU. It is mounted on a metal tab on the underside of the battery tray. It's function (acting in concert with the RLU) is to advise by warning lights of the operating condition or lack thereof of the tail & brake lights.
As I understand it......if you've a disabled or removed RLU....you might just as well remove the LCU as well. finish of the Simpla Fi treatment which I choose to do on the upgraded electrics of my "Blues Mules"...if you choose to do so, you will need to supply a power feed to the tail light L (blue) from one of the blue supply options, I chose L/y because I wanted the tail and tail/brake to remain functional if someone is following me on a trail eg but there are several others...L/G, L/B, L to choose from for various reasons etc. Oh, of course the tail light/brake light
indicator light no longer operates. If you do all of these simplifications you should still have.... turn indicator lights, neutral and high beam indicators.
OK 5 twins, not my 'turf' really. I gladly defer to the electrical gurus like Pete, Grizld1, TRG, Ken Maxwell and on and on. So retired old chemist that I am, I say in summary "Where's that guru #9 when you need him? Pete has written well as has TRG on this subject in the previous posts. Might want to search it?
Hope this helps, Blue
