Duralast AGM Gold
Not enough info in that listing ad to know. Is it same configuration as YB14L-A2?: positive on right front. It should specify, but doesn't.
Pulled the trigger early based on this thread https://www.xs650.com/threads/what-battery-is-everyone-using.37060/post-372746
Even after putting a new battery and changing the rectifier - the bike starts and runs but the battery after cranking and revving wont charge beyond 11.8 seems there is a voltage leak somewhere and the alternator and the brushes seem fine too... Any clues ?
while idling , if you revv it to 3000 rpm, I should get > 14 volts on my battery but its ceils at 11.8 to 11.89. Rotors ??
So your mechanic replaced the regulator/rectifier combo and other stuff (?). Runs now, but not charging? We may need pics and part numbers to figure this out.
I'll make a suggestion suntosh, add all the pertinent info on your bike in your signature. That way it's all readily on hand when you ask a tech question.
Like this:
Like this:
Noted @Jim . I just got this beauty barely a month ago and I am just discovering what I have based on the questions you ask. As much as I know this is just as stock as it gets - an XS650H with all original parts. Just changed the rectifier and the battery. There are the first custom parts I have on the bike AFAIK
The original rectifier is here - https://drive.google.com/file/d/1hooXklcqyx1Yv3CplLrIC7-Xf3vJxxzp/view?usp=sharing
Here is short video showing the wiring - https://drive.google.com/file/d/1hpRizofmititQP-eV5iKgSUDQscG6YfX/view?usp=sharing
Yes it is the xs650H based on the VIN and the pic @jpdevol posted.
Sorry, my security settings won't let me access those links...
There are different ways to diagnose the issue. Attached is the procedure per the manual, if you have a multi-meter, just follow the steps. The issue should show-up before you get to the rectifier test (last) - if not, there may be a wiring problem (bad ground, broken wire)
  • img064.pdf
