I have enough center stands now. Thanks all!
Just put an early bike on the lift for a "restore" and problem #1 hit. someone has cut away the RH most centerstand bracket and the center stand is MIA also. So looking for these parts.
Bracket
Centerstand
Centerstand spring and bolts.
Any of you bobber chopper guys have em?
Has to be from an early bike
1970 1971 1972 1973
XS1 XS1B XS2 TX650 Not from a 1974 TX650A or any later bikes, the early center stand is narrower.
pic of the bracket I'm missing the bracket was cut away close to the frame.
one of a frame with that bracket still on.
Note if you were cutting this off, both inner and out brackets are tied together with a square section tube I will need that also. OR a chunk of frame with both brackets still attached would be nice.
Thanks!
Bracket
Centerstand
1970 1971 1972 1973
Thanks!
