Now I never had an early XS with 34 mm forks, but I do have a -77 standard with the later twin disc front brake, and a couple of RD 350s with the same single disc brake and opposed piston caliper as the earlier XS models.
The stock, later XS dual disc setup can best be described as piss poor and pig heavy.......
At least on the much lighter RD 350, the opposed piston and single disc setup is a very good brake for that period. It may be that the 35 mm fork offers some advantages over the 34 mm, but the later brake caliper and disc design is definitely no upgrade, in my opinion. If possible to do, a dual disc setup with the earlier calipers and discs would provide the best braking using oem components. If you decide to upgrade to a modern disc/caliper combination, the 35 mm fork would be a worthwhile upgrade
