BigBoreSwede
Hi.
Today I reassembled the pistons and cylinder fort the first time ever. Fun and a little scary.
As many here at the forum suggest I´d put the pistons in the cylinder before before mounting them at the rods. Worked just fine! The issue was to fix the cylinder "floating" while push the pin in.....( "push the pin in" he he he he, sounds funny)
So I came up with an idea using some hose clamps on the studs. After some simple mesuring I bolted them on and after the pin was in place I just took them of and slide the cylinder down. The whole procedure took about 10 min.
Now I know there´s a whole lot of good ideas around this subject and they are GOOD But I think this was really fast and you don´t need to mesure much.
I do have one question: In one pic you´ll see a screwdriver pointing at the base gasket. This area in between the barrels, it don´t really make any sense huh?? Why is the gasket shaped like that?
/BigBoreSwede
/BigBoreSwede
