Ramjamjungle
XS650 New Member
Thought I would pass this along about mounting an inexpensive 1/4 fairing like this Emgo, available on eBay.
After much thinking about how to use the mounting brackets that come with the fairing I decided to forgo any brackets and cut some U shaped slots in the side of the fairing. Simple to do with a drill and file or a jig saw. This allowed the fairing to fit over the turn signal stems and come up tight against the headlight housing. Then I drilled a small hole in the fairing ahead of the U slot and zip tied the fairing to the turn signal stems. No alterations to the bike required and easy to put on and off. Seems to be plenty secure at all speeds.
