bloodthirstysystem
Been getting a lot of info from this board, now i finally have a question. This is a 78 standard with pod filters, straight pipes with large washer baffles bolted in.
Left pipe is turning blue, right side is normal. Carbs have been cleaned, rejetted, mix screws set, needles at 3rd slot. Exhaust valve is .006, intake .004. Plugs are tan at the electrode and both sides look the same, ignition timing set with ohm meter.. runs great.
Has anyone else had a problem with this?? maybe the exhaust valve isn't closing all the way? I need to do a compression test but thought i would ask here..
thanks
thanks
