Tim of DO THE TON
XS650 Junkie
Yes - I feel dumb for not having stuck with the Radian arm. I can't remember why I decided against it. I might not have had the axle adjusters/axle from the Radian which has a smaller diameter and longer axle than the XS (17 vs. 20mm). If you have the axle adjusters and axle, this becomes an easy bearing swap.
My current Radian arm has all the bits. So I just need to move the shock mounts, replace the needle bearings, swap out wheel bearings and buy a longer chain. We'll see if/when I ever bother.
