I was having some issues with the BS38's I was running. Occasionally fuel leaking, off idle stumble. Low mileage.
I finally swapped them for a set of BS34's from the parts bike.
The jetting is all stock. 132.5 mains, 42.5 pilots. Air screws set 3 1/4 out. The same mods as always, 750 kit, cleaned up ports on head, Unifilters, Mike's 1.5 headers, Emgo shorty mufflers.
Runs very well. Needs very little choke, idles well. no off idle hesitation. It doesn't pull as strong as the BS38's, I think I need to go up one on the main and shim the needle. It has a very slight hesitation in the 7/8 to full throttle area. Milage about 57 mpg on the first tank full. I was running it kinda hard to test the jetting so it might be better on a regular ride, know better next run.
After I got the BS34's on I was looking over the BS38's. I think one of the diaphrams is bad. When you lift the slide, plug the hole, release the slide the left side stays up, the right slowly lowers. About 5 seconds. Between that and the bad floats or float valves could have been my running problems.
I know that the BS34's use the large round main jets, can the small round main jets be used just for testing? I have plenty of them. Once I find the size the bike likes I can buy the right ones.
One other thing, the 75 steel side covers won't fit on the bike with the BS34 carbs. Guess I'll have to mod a set.
