jkeller1992
Hello all! My name is Jesse and I have just recently picked up my first motorcycle, an xs650, of course.
I have a lot to learn, and hope I'm not wasting all of you guy's time with these questions.
Here is my situation:
I have cleaned my carburetors by dissembling and soaking the full assembly in a gallon of carburetor/parts cleaner. They didn't seem very dirty, but I still took the time to use the cleaning tools, etc. to make them perfect.
I also ran new vacuum lines into the backs of my pod filters to imitate the factory air box set up.
I've cleaned the wiring harness up completely, and even updated the glass fuses to blade fuses.
Last night, I got my bike all back together after doing a clutch case gasket replacement
and putting my exhaust on.
With one kick, it started no problem and sounded great. I did notice though, that it required me to give it a little throttle to keep it sounding like a truly healthy idle.
I didn't think anything of it at the time, it was cold and rainy last night and I did start it with the choke not on.
Anywho, before I drag this out any longer, I went to ride it today and it started just fine. Idled healthy under it's own power for about 3 minutes, then shut off. I started it again and tried to take it for a very brief spin around my apartment parking lot. Under throttle, it seemed to lose power and bog down. It then shut off again. I did some small tinkering to it, and tried starting again. It will now not start.
Also, I believe one of my petcocks is leaking gas. Rebuild kits for those are on the way!
Any general tips, tricks, advice? Should I just rebuild the entire carburetor?
