cmattina1
In reading my manual I see that my float should be 24mm +/- 1mm. I get that, and i get how to measure it, however, I am curious about bending the toungue. If i understand correctly, I push the float to the top (bottom of carb body), and see where the tounge is.
Am I correct in believing that the tounge needs to be parallel with the bottom of the carb body? As in: if I push the float up to the top and the tounge is still not parallel with the carb body i need to push it in (up) until itis or until the pin is seated correctly? OR if I push the float up and the tounge gets parallel or seats the pin in BEFORE the carb is all the way to the top, i need to push the tounge out a little bit?
